AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › How to hide/cover a tv bracket a tv isn't doing so already
post #1 of 5
There's a TV mounted on a middle wall, and as you walk in to the room you can see the bracket clearly. Wanted to know what others have done to hide/conceal it. Can you get plastic moulds to cover them?
post #2 of 5
Kinda the wrong Forum to ask about such on....but in the past I have Draped or Wrapped Black Velvet.....or painted the mount the same color as the wall.
post #3 of 5
DIY & screen.. thought I hit the nail on the head :/
Now a days you get tvs everywhere, so there must be a more commercial solution with plastic molds. The brackets can fit it close to the wall but don't allow for angle ajustment.. which then causes the problem when they have.
Thanks for the input
post #4 of 5
Screen, as in Projections screen.
But now it is here, a picture would help.. Not much other than camouflage or replace it with a lower profile mount that is of the proper size.
If it is an articulating mount like I have in the living room.. not much you can do until wireless levitation becomes science.. wink.gif
post #5 of 5
Photos as asked. When the room is bright it stands out too much.
20131004_190837.jpg 96k .jpg file
20131004_190900.jpg 127k .jpg file
20131004_191055.jpg 120k .jpg file
  Back to Forum: DIY Screen Section
