AVS › AVS Forum › Video Components › Home Theater Computers › XBMC and CIH 2.35:1 screens
post #1 of 11
I'm starting to configure my xbmc pc and wondering how people are using it with scope screens.
Has anyone modified a skin to work with this aspect ratio?
post #2 of 11
I ended up running a custom resolution on the desktop (1920 * 800) and then using the PM3-HD skin and setting XBMC to run full resolution (1920*1080) and THEN setting the zoom features within XBMC appearance options to -20%, so the skin fits decently and then 2.35 video plays at the proper resolution, for 1.78 I adjust it when I watch the video the first time.
Bill
post #3 of 11
Thanks Bill, you've given me something to go off of. I'll see if I can replicate that.
post #4 of 11
Good luck. I had ZERO luck finding a skin made for CIH so that was my solution, if you try other skins you will quickly notice that they actually HIDE the side menus off the screen which if you set the zoom that way you can still see mad.gif
Bill
post #5 of 11
Interested in testing one?
This is a skin I am working on adapting based on Aeon Nox.  So far I have most of the video tree done and a simple setting switches back and forth between CIW and CIH.  Note the skin cannot auto zoom your 1.85 movies to fit, or detect AR and change based on that (due to XBMC not knowing 2.35 films in a 1.85 container are 2.35).  I do not plan to do the audio, pvr, pictures and other parts of XBMC, just the video tree to display my movies on my CIH projector setup.
I have almost completed work to get this much out.  I don't know yet where I will post it.  When I do, I will follow up this post and one I have responded to on XBMC.  Hang in there...I've been waiting many years for a CIH XBMC skin, I finally decided to help myself....hopefully it may help you as well soon.
post #6 of 11
Hi DoghouseCinema,
your skin looks great. That is exactly what I am looking for.
post #7 of 11
I'll give it a try! Aeon Nox is what I run so i'm extremely interested.
post #8 of 11
Quick question for you guys...what content do you display on your CIH screen?  Audio, Pictures, TV, PVR etc....
Are you using a zooming projector for 1.85 content, or just showing 1.85 content at reduced resolution?
What AR is your CIH screen?  2.35:1, 2.40:1 etc..I did 2.40, but know others have 2.35...I don't want to miss a common AR
Originally I was just doing the CIH thing for the Movie/Video Tree, but I have just about completed modding the entire Confluence skin for CIH.  (Aeon Nox is a complicated skin, wanted to get a better idea of structure thus the work with the simpler Confluence...I have the video tree mostly done in Aeon as seen above).  As such, I have decided to do full mods to three skins, Confluence, Ace, and Aeon Nox and your input will help as some variables need to be setup from the start or it means going back and redoing stuff.
Thanks for you input.
post #9 of 11
Alright.  I have set up project pages for the skins I am modding.  You can find them at my website http://www.doghousecinema.com
Confluence has quite a bit done.
Aeon Nox has the video tree mostly done, and work on the rest has begun.
Alaska HD work has started.
Rather than do Ace, I have decided to wait for Aeon MQ5 to be completed by MQ and then mod it.
post #10 of 11
i have done one using the "refocus" skin. It's converted to 2.35.1 then themed it like imax.
have a look. youtube - http://www.youtube.com/watch?v=NujRMr4apCk
post #11 of 11
can you post a link to the skin? looks great,
