AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Three sub choices - Dynamo 300, Dayton Sub1200, or Bravox DIY
post #1 of 2
Greetings,
I'm looking at a new subwoofer solution and am wanting some opinions. I have the option of the Martin Logan Dynamo or Dayton Sub 1200 at roughly the same price. I also have the option of using an old 300W Bash amp I have and a Bravox driver Here. With associated expenses like box, port, etc. the cost will definitely end up at around $100+ too. My total budget is up to $150, and used is acceptable if anyone has other ideas of a good budget sub.
My associated speakers are as follows:
HT: NHT SuperZero XU x 5
Music: Martin Logan Motion 10's
The room size is roughly 14 x 14 or so from what I can tell with a lower (8'?) ceiling. Not very large overall.
A smaller footprint is pretty necessary though (18x18" on floor max), I've done the big sonosub before and it's just too much of a pain for me.
post #2 of 2
It depends on usage. Are you planning on using more for music or movies?
