AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › A good match for a Rythmik F12SE
post #1 of 13
I'm looking to add a second sub to my system. I've looked for a used F12SE but I haven't been able to find one. A new or B stock one is a bit out of my budget right now. Any suggestions on a sealed 12" sub preferably in piano black or a black finish to match up with the F12SE? Thanks smile.gif!
Bill
post #2 of 13
I would think the SVS SB12NSD would be a pretty good match up. About the same size, piano gloss black, quality driver from Peerless and a DSP amp.
http://www.svsound.com/subwoofers/sealed-box/sb12-nsd#.UlMasxCArq4
post #3 of 13
If you throw in any other sub with a Rythmik, you could end up bluring its distinctive sound thereby losing what value it has in the first place. The only other sub that should be run with a Rythmik sub is another Rythmik. Save up and get another another one.
post #4 of 13
Remember that as a returning customer you get 10% discount in you next purchase. We have a couple of F12SE b stock if that helps.
post #5 of 13
Thinking about getting another fv15hp. Do I still get the 10% discount if I bought the first one about a year ago? Also is the 550W fv15 still available? Thanks.
post #6 of 13
Cowboy, I believe the 550watt amp has been discontinued since early summer. However dual FV15HP's is some major subwoofage! I say just get the 600watt version, not much difference anyway.
post #7 of 13
No matter how long ago you bought your first FV15HP, as a returning customer you have 10% discount in your next purchase. The H550 amp is not available anymore but I think we still have some for customers who want to buy a matching subwoofer. If your actual FV15HP has the H550 amp we can sell you one with an H550 amp for perfect match. But like I said I need to check with Brian if we still have H550 amps.
post #8 of 13
^^Please check with Brian as I would prefer perfect matching beside less ca$h with the 550W. Since I am in TX, I had to order mine from ascendacoustic to avoid tax. I assume I still can get the 10% discount with them ordering my second one? Sorry for derailing this thread. Thanks.
post #9 of 13
Thanks everyone for your thoughts smile.gif.
Enrico,
I bought my F12SE used so I would not be entitled to the 10% discount. But that is a great offer and one that I will keep in mind for the future smile.gif.
Bill
post #10 of 13
I would just save and/or look a little longer and get another Rythmik...
post #11 of 13
+1
post #12 of 13
Enrico,
Bill
There is a used F15 for sale in the Audio Gear section.
post #13 of 13
Thanks for the heads up smile.gif. I saw that one and the F15 is too large for my room. If I stay with Rythmik as I'm sure I will then I'd like to have matching F12SEs.
Bill
