TMT 6 Help
post #1 of 9
TMT 6 will not, no matter what setting I change, quit starting every time I insert a disc into my bluray drive. I'm sure I'm missing something simple, but for the life of me can't figure it out.
I would prefer to not have the program start automatically. Add to that it starts in full screen mode which just adds to the annoyance.
post #2 of 9
Bump
post #3 of 9
What Os are you using? So if you go to the auto play options and change the settings it reverts back?
post #4 of 9
Windows 8, 64 bit. The setting doesnt revert back. It stays unchecked. Thats the odd thing.
However every time I enter a disc it opens in full screen and has to load the disc before I can close it. Very annoying. Id like to not have to buy another program if at all possible.
post #5 of 9
There should be a drop down tab which you should be able to pick ask me everytime.
post #6 of 9
Is this the drop down you're talking about? I tried this configuration and the program still opens up when I insert a disc.
post #7 of 9
post #8 of 9
In older versions of Windows, if you held the shift key down while the disk is inserted it would disable any auto play functions and simply load the disk. Give that a try.
post #9 of 9
Gosh the little things... thank you. Problem solved.
