AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Banana Plugs
Banana Plugs
post #1 of 6
Just a quick one hopefully...
I want to run four speakers from one amplifier but I want to make the connection with banana plugs, Can I put two lots of speaker cable into 1 banana plug?  I assume you are limited to how thick the wire is but in principle is it possible / recommended?
post #2 of 6
Yes, basically wiring the speakers in parallel which will reduce the impedance by 1/2 (ie. if 8 ohm speakers, the amp would see a 4 ohm load).
post #3 of 6
Make sure your amp can handle 4 ohm loads then.
What amp/receiver do you have?
post #4 of 6
I have a rotel Ra-15 amp and Kef LS50 speakers.  The additional speakers I want to attach are Kef Q35's
post #5 of 6
Does that amp have a set of A and B speaker terminals?
post #6 of 6
A & B, yes it does
