AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 2311 dying? Video and sound cutting out
post #1 of 3
Hi everyone. I have a demon 2311 that is cutting out periodically regardless of source. It'll cut out for 4 or 5 seconds, loose sound, loose video and the input indicators disappear . At first I thought it was a bad hdmi cable, but it's happening with multiple sources. ( Xbox , directv). It's happening when the unit is not hot. What gives?
post #2 of 3
Try unplugging the unit for 10 minutes and if still no joy, then reset the microprocessor (p. 84 OM). Otherwise, if purchased from an authorized dealer, the unit has a 3 year warranty so check Denon's website to see if there is an authorized repair shop in your local area.
post #3 of 3
Cool. I'll give it a try. I bought it from electronics expo which I believe is an authorized dealer.
