AVS › AVS Forum › Audio › DIY Speakers and Subs › My first speaker build. looking for most bang for the least buck :)
post #1 of 15
I've been talking to fellow AVS member Scott Simonian and he encouraged me to make this thread. Here's the setup:
I'm in charge of bringing in a sound system into a classroom lab. the dimensions are roughly 25x30x15.
I want to build a 2.0 system to begin with and then possibly add a subwoofer in later. The speakers will be mainly used for music and videos.
Here are the constraints:
$300 budget
-size or shape is no concern (however the easier it is to place/mount the better)
-build quality or finish doesn't have to look great
-doesn't have to reach home theater reference quality but am looking for best bang for the buck
I have an uncle that has a table saw and other power tools so I have access to that. I'd prefer to not get too crazy with the build process so the simpler the better. Scott recommended the following to start with:
(2) - http://www.parts-express.com/pe/showdetl.cfm?partnumber=290-504
(2) - http://www.parts-express.com/pe/showdetl.cfm?partnumber=290-530
(2) - http://www.parts-express.com/pe/showdetl.cfm?partnumber=290-636
(2) - http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-309
What do you guys think? We were talking about making a sealed box would be the simplest. How would I go about making a box for this? Thanks everyone for looking. Please let me know if I need to put more information up.
post #2 of 15
http://www.musiciansfriend.com/pro-audio/peavey-pr-12-speaker-pair
12% off this weekend makes it $300 for a pair.
done.
post #3 of 15
post #4 of 15
more reviews at parts express: http://www.parts-express.com/pe/showdetl.cfm?partnumber=248-829
Thanks for the link! I was hoping to build a pair of speakers though
post #5 of 15
i know...
the problem is that a cheap kit: http://www.diysoundgroup.com/waveguide-speaker-kits/karma-series-kits/karma12-kit.html
costs more than the cheap speaker.
and putting a good speaker in that room isn't going to sound good anyways.
with those bare walls and floor, the reflections will never die down. acoustic panels on the walls would be a good diy project for that room.
post #6 of 15
have a listen to this video comparison of a "live room" like you have there and a treated room.
play the video a couple of times. the sound during the first part that sounds like rain on a tin roof is all the reflections bouncing around everywhere. your room will have that effect too.
http://www.youtube.com/watch?v=m6PMchgv2C4
post #7 of 15
+1 on the room's acoustic treatment
That space screams for treatment, and clearly such treatment/or lack thereof, is the dominant component impacting sound quality in that room.
Regarding loudspeakers, yeah a current pro type budget offering does represent huge value, but I understand the compelling reasons to DIY too. Whatever loudspeaker approach you pursue, will sound unintelligible unless you address the acoustics.
post #8 of 15
Heheh. Every room will need some acoustic treatments....
post #9 of 15
+1 Whatever loudspeaker approach you pursue, will sound unintelligible unless you address the acoustics.EoRNcTacoustic panels on the walls would be a good diy project for that room.
post #10 of 15
if you don't like scott's idea...ride the econowave!
http://audiokarma.org/forums/showpost.php?p=1675101&postcount=1
post #11 of 15
scott's idea isn't too bad either. that coaxial is also on sale for $57 http://www.amazon.com/Eminence-Beta-12CX-12-Coaxial-Driver/dp/B000BBF43Q
post #12 of 15
2.0 cubic feet stuff with polyfill or fiberglass medium heavy
100 watts, 2 pi conditions. actual in room response should be flat to somewhere around 50 or 60hz depending on placement.
ideally they would be placed in corners up near the ceiling and aimed roughly at a person sitting in the middle of the room.
as a sealed design without a lot of xmax, they aren't designed to pump out def beats of bass, but should do just fine with drum kicks for most music at what most folks would consider medium-loud levels.
nice idea scott. i still think the peavey's would outperform, particularly bass side, but where's the fun in that?
post #13 of 15
You're right
post #14 of 15
I'd either mount them up in the ceiling/front wall junction, with relatively tight pattern control. Or, A/V cart them, with an eye on critical distance, and keeping overall levels down, listener to speaker distance short, subjective levels and impact up.
Problem is, portability is ok, but opens up a can of worms; damage, set-up inconsistencies, theft, etc ..
post #15 of 15
Hey, Jorge. How is this going?
Order anything yet?
