AVS › AVS Forum › Audio › Speakers › Martin Logan MLT-2 deal
post #1 of 17
Newegg has it for $169.00. These are the rebadged paradigm?
I just bought some like new Energy V-Mini fronts. Still want to upgrade the rears and sub.
Should I have bought these instead?
http://www.newegg.com/Product/Product.aspx?Item=N82E16882981013
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
post #2 of 17
V mini's are better than the MLT-2 speakers, they cost a lot more too. Much better finish, wood vs plastic, better drivers.
But for $169 for 5.1 can you really complain about the MLT-2?
Read the reviews before you buy, lots of discussion about the failure of the MLT subwoofer.
post #3 of 17
How does the MLT-2 compare to def tech procinnama 600? I've listened to the 600's at least.
post #4 of 17
Don't know, never heard the pro cnema...
post #5 of 17
Really!!? Whoa!!!
post #6 of 17
The pro cinema can be heard at best buy magnolia.
post #7 of 17
I lost interest in satellite speakers a few years ago and moved up to bookshelf speakers which provide a fuller and better sound..
But if you have space limitations sats are fine.
post #8 of 17
I do have space limitations "wife limitations" so I order the Energy V-Mini.
post #9 of 17
Ask her what it would cost to do an "upgrade" to remove her limitations wink.gif
LOL
post #10 of 17
Look at a review here
http://www.avsforum.com/t/1308934/compact-5-1-systems-for-motorhome
Edited by zieglj01 - 10/12/13 at 2:07pm
post #11 of 17
LOL
I bought v minis due to the low price. $300 for front and centers. Haven't had a chance to hook them up. Still need a new sub and surrounds. Hope ill like them. What I winder is if ill enjoy the more than say these MLT 2s.
post #12 of 17
Check out fluance bipolar surrounds. good deal
post #13 of 17
His review of the Take Classic says it has a single 3" midrange but he doesn't mention the 1" tweeter. And it comes with a 8" sub not 10".
But at least he reviewed multiple 5.1 system.
post #14 of 17
LOL
To keep the wife happy with a small speaker setup, how about some Cambridge Minx Min 21 speakers for the rear? Use their small size to negotiate getting yourself a good sub like the SVS PB-1000 smile.gif
post #15 of 17
The size of the Energy Veritas V-Mini are not a issue. Don't want to go smaller. Just thought since the price was so good on the MLT2 I might just use that instead of the veritas v-mini. Would it be better to go the route of the MLT2 set NOW? Or, build the rest of the home theater with veritas v mini and a better sub (which might take me a bit more?)Thanks all for your expertise and insight.
post #16 of 17
The v-minis will look better and sound better than the ML satellites. You could find some Take satellites for cheap to round out your surrounds. They are easy to find on eBay.
post #17 of 17
  Back to Forum: Speakers
