AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Magnavox HDD DVD Recorder Issue-Recording with HQ Speed
post #1 of 2
I have had this unit for a couple of months and love it! Normally i use the SP speed setting, but decided to try the HQ Speed. The playback of the recorded show was extremely jumpy. Is there some adjustment I should make it my settings to fix this problem? The recording was made through the unit's tuner (Local HD channel).
post #2 of 2
I have made/make all of my recordings at HQ with a 2160A and 515H. I have never seen this issue.
I would try component if you are using HDMI (or visa versa). Magnavox has a very active forum. Try there.
  Back to Forum: DVD Recorders (Standard Def)
