post #1 of 1
I have a win7 htpc connected to a denon avr891 which is connected to a samsung dlp. Usually everything works fine. The only issue is if I turn my denon on while the pc is on. I get a no signal screen with the denon logo on my tv. I have to change the input to something else then change not back to the input assigned to the htpc's hdmi.
Does anyone have a fix. I just tried moninfo edid override to merge the displays but that didn't help. I also changed the hdmi ports that I use on the denon but that didn't change anything.
What should I try next?
