AVS › AVS Forum › Audio › Soundbars › Sony Audio/Video/Game setup
post #1 of 4
I have a PS3 system, and recently got a Sony KDL-40R450A TV. It has only 2 HDMI ports (one of them is ARC). I have been planning to get a soundbar, most likely the Sony HT-CT260H.
I have been researching for some time now, but I don't understand the "3D pass through" feature this sound bar supports. Does it mean I could connect a HDMI from PS3 to soundbar, and another HDMI from soundbar to TV?
In other words, does this look correct? PS3 --> CT260H --> 40R450A?
The spec on the Sony website says "HDMI™ : 1 In / 1 TV". Does it mean it has 2 HDMI ports or just 1?
I want to understand what would be a good way to connect the three together so that I get good sound and make use of Bravia Sync.
Many thanks in advance!
post #2 of 4
ps3>soundbar>tv
3d pass through means the soundbar will allow 3d content through. Some soundbars wont pass 3d through.
I dont see any hdmi ports on that one. Are you sure?
Edited by shamus - 10/13/13 at 10:07pm
post #3 of 4
Thanks for the reply.
Yes, the new model CT260H has HDMI ports added. I believe the older CT260 didn't have any.
post #4 of 4
ok... i see. it looks like you have one input and one output. You might want to check out this thread and upgrade if you can...
http://www.avsforum.com/t/1487773/sony-ht-ct260-vs-ht-ct660-mini-review
  Back to Forum: Soundbars
