AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › Music Server??
Music Server??
post #1 of 4
My Fireball Music Server died. As I found out Fireball is no longer in business. So it seems it is time for an upgrade of some sort. I really loved my Fireball Music Server. It has worked well for me and did what it was made to do for 8 years.
So in my search for some sort of replacement for it I have found that there is nothing like it anymore.
The closest thing I have found to replace it was Sonos connect. I don’t know if that is the answer to replace the fireball or not. I know I would have to have a computer on all the time for it to access and I would not have the onscreen guide. Not that either one is a deal breaker for me. I also liked the Logitech’s Squeezebox but it has as it has been discontinued I don’t see the point of doing that unit either.
I feel out of touch with all the new technology out there. So thought I would pose the question to you guys that are a lot smarter about this than me and ask for some guidance on this. Is there something out there that is better I can put my CD’s on and can assess them from my stereo for less than $1,000.00?
post #2 of 4
You can still find some very good deals for used Fireballs on Ebay and Craigslist. I just purchased one myself. If you need to purchase a "new" server, try the Olive series. These function in the same way as the Escient Fireball.
post #3 of 4
Look around at CompuerAudiophile dot com.
http://www.computeraudiophile.com/
I had a 2010 mac mini setup as a music (only) server and it was AMAZING.
now, I use a first gen AppleTV as both a music server and also a video jukebox and it's also great.
In particular have a look at the CAPS (Compact Audiophile Pocket Server) projects there. (I think they run Windows (eek) so I have Zero interest but lots of people like windows so it's viable for many.)
-Brian
post #4 of 4
The Sonos does have to connect to your router but you don't have to have a computer on to listen to music and there is a controller but a better bet is to download a phone app to control it. It's pricey but it works.
