AVS › AVS Forum › Display Devices › CRT Projectors › Need lens covers and long back plate for Marquee 9500
post #1 of 3
I'm looking for the following for my Marquee 9500:
- Lens covers (all 3... no idea where they went)
- One of the long back plates, where there is currently just an empty hole covered by tape. (Doesn't need any inputs; just a blank plate.)
Anyone know where I can get these? No luck searching on eBay...
John
post #2 of 3
cover plates are common, I have a few here, lens covers a little more difficult to find.
The lens covers are important only during transport,if sunlight strikes the lens,it will burn the plastic -C-element (first lens component) behind it. Otherwise, a can of dust-off is all you need in your theater,
post #3 of 3
I'd like to buy one of your cover plates if that's okay.
For the lens covers, I am actually about to move from my current home (probably in a few weeks). My PJ is already down on the floor, with bubble wrap temporarily protecting the lenses.
John
  Back to Forum: CRT Projectors
