AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Projector or TV ?
Projector or TV ? - Page 2
post #31 of 37
Originally Posted by coderguy View Post
10% to 50%, a good average is 20% to 35% is the norm at 1000 hours.
Yikes, that puts the half life of the bulb at under 2000 hours. Luckily for me LG are releasing a 1080p LED projector soon for a reasonable price. I'm keeping a close eye on Amazon and the thread for it.
post #32 of 37
Remember we do not see light in a linear manner. We are unlikely to be able to notice a 10% change in light for example.
post #33 of 37
^ yep, the eyes are a neat invention!
post #34 of 37
Do you use that 70 inch TV in the living room or theater room ?
Perhaps if you can hold out until next year some more 1080p led projectors would be coming out on the market.
post #35 of 37
Family room with lots of light. I was going to convert a spare bedroom into a dedicated theater room next year. I like to start my research early and plan things out. biggrin.gif
post #36 of 37
The bulb does not dim linearly, it dims the fastest in the first 1000 hours, then after that point it dims much slower. For instance a bulb that dims 35% in the first 1000 hours may only dim 15% in the next 1000.
post #37 of 37
If the projector is sized correctly for the screen size, gain and throw to start with, normal light loss though aging is not a problem. People tend to buy over sized > 120" screens and a projector that can just about light up that size with a new lamp. Then 500 hours later they are pissed when there isn't enough light.. The manufacture may say image from xx - xxx but that is just how big the lens will make the image not that the projector can actually light it up to a sufficient level to be watchable.
