AVS › AVS Forum › HDTV › HDTV Recorders › Pioneer SD-532 hd5 Won't Come On (PS Has been re-soldered)
post #1 of 4
Yes, it's the ole' Pioneer SD-532 hd5 that had the popping/flashing/turning off issue.
The power supply was recently resoldered, it worked great! On day 10, I turned it off one night as normal, came back the next night and wouldn't turn on, at all.
Any ideas as to why? Is it still the power supply or some other issue? I'm pretty much giving up on this thing, but I'm always curious as to what happened. And if it's a relatively easy/inexpensive fix I will.
Thanks for reading.
post #2 of 4
Buehler? Anyone?
post #3 of 4
You might get a better response if you post this in the correct forum (Display Devices, Rear Projection Units). Mr. Bob will probably see it then.
post #4 of 4
Thanks! Didn't realize I'd posted under HDTV recorders....
  Back to Forum: HDTV Recorders
