AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › LCD would be dead and buried
post #1 of 4
If plasmas ran an uncompressed CG demoloop running at 120fps LCD would be dead and buried five years ago
It's not the technology that is bad nobody even knows what its capable of
Let me tell you its as clear as when you look out a window
-Chad
post #2 of 4
No, they wouldn't.
Plasma is limited to around 60Hz anyway - the panels may be driven up to 3000Hz FFD for the high end Panasonic plasmas but that's mostly marketing nonsense - there are only 60 different images per second.
With new plasmas, you've got aggressive ABL which always annoys me when I'm watching. My older 2008 Panasonic hardly has any ABL -- but this comes at the expense of more energy consumption (up to 600W for a 46"!)
Black levels don't show well in shops, nor do reflective screens.
LCD has a place imo. For 42 inch and below, for people who do not mind about having average picture quality because they just want a TV.
post #3 of 4
Plasma is not at all limited to 60Hz
I can run any refresh rate up to 125Hz on my panel (TH-42PF30U) and every 3D capable plasma is capable of similar or higher refresh rates technically speaking
The added realism going from 60 to 100hz is like jumping from 480p to 1080p
The only limitation exists in the interface used (HDMI 1.4, VGA, single link DVI)
What a damn shame we will never see display port to showcase the full potential of plasma
-Chad
Edited by ChadThunder - 10/18/13 at 4:27am
post #4 of 4
By the way according to this review by Chad_B higher refresh rates translate into even lower black levels
-Chad
Edited by ChadThunder - 10/18/13 at 4:26am
