AVS › AVS Forum › Audio › DIY Speakers and Subs › DIY sub and Audyssey XT32
post #1 of 4
I have an Onkyo TX NR1010 with the best Audyssey available and the sub eq ht.
Does this handle all the sub eq'ing that is necessary or something like a mini dsp still recommended?
I know the sub eq ht is for dual subs, which I have. Just curious if all that on board software takes care of everything.
post #2 of 4
It depends. Do you have a sealed sub(s)? If so, then EQ'ing the bottom end with some boost can make a fairly large difference. If you are referring to the high pass filter in a ported sub, then I would recommend using a MiniDsp or other similar EQ devise for that as the XT32 will not be able to set the HPF to protect your driver.
post #3 of 4
I think I'm right in saying that Audyssey only EQs down to the -3dB point?? (With 10Hz minimum?)
I may well be wrong, though... lol
post #4 of 4
Need more details on DIY sub.
If the sub is self sufficient in its design, Audyssey does a really good job of EQing the response flattish and setting delays etc.
Do you have measurement capability? I assume you do since your talking DIY speakers and outboard manual EQ...... If not, your first purchase should be a USB mic and download REW or other measurement software. The Minidsp wont help you much without the ability to measure.
I have the older MultEQ XT and have found benefit in external manual EQ. Your version(Audyssey) has more filter resolution so IDK how much you will find it useful.
