AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › Runco VIVIX II DVI to HDMI
post #1 of 4
Sometimes you must work with what you're provided with.
I'm using a Dish Network Hopper connected by an HDMI to DVI adapter cable.
Everything is well and good until the processor/projector are turned off.
When the system is turned back on I have no video until I reset the Hopper.
Is there any way to prevent this?
Thanks for the assistance,
Greg
post #2 of 4
Greg
Does powering on the Hopper before or after your projector make a difference? If so, simply program that macro into your remote. Or program a reset into your remote when powering on the projector. Then at least the hassle is automated.smile.gif
post #3 of 4
Update: Turned out to be that the dvi ends created bad connections. A poor design choice.
 Thanks thebland,
After posting I had the thought that if I went to settings on the Hopper and changed the TV format from 1080p/1080i to 720p I might resolve the issue. . . Didn't work.
Once the projector has been turned off (along with the Vivix II) when it has been turned back on and Dish selected, the Hopper must be reset to restore images. Sound is fine but the screen is blank.
Having to reset the Hopper every time the system is turned on isn't a practical solution when you have others accessing the same unit for their viewing pleasure.
Unless there are any other ideas it would seem that my options are limited to:
1) Swapping out the Hopper for one of the Joeys and then figuring out how to program a reset or doing a manual reset.
2) Pulling out the rack and to disregard the HDMI connection and use the HD1, HD2 or the Componet Video input.
Hopefully there's a better way?
Thanks again
Edited by TeacherMac - 11/20/13 at 10:43am
post #4 of 4
How about if you change the hopper's resolution (via remote) while in blank screen mode? Does that get it going?
If so, a simple resolution change command to your remote system macro after powering on hopper would be a nice workaround.
Or maybe an HDMI/DVI cable change?
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
