AVS › AVS Forum › Audio › Receivers, Amps, and Processors › searching receiver or processor
post #1 of 12
Hi im searching for a receiver or processor with parametric EQ, for all channels to use with REW.. any ideas?
Budget is around 4500 max
Tks
Dan
post #2 of 12
Tks
Dan
Cary and Rotel come to mind.  NuForce for much less and Classe or IAP for more.
post #3 of 12
whats the price if the IAP processor?
i cheked the nuforce , but apparently their parametric eq is not the same for the subs
post #4 of 12
About $21K.
post #5 of 12
that out of my budget,, so for around 5000 or 6000 what can i get?
post #6 of 12
I'm out of ammo.  Mebbe the Krell Foundation but I have not tried it yet.
post #7 of 12
Used to be in the 000's now on closeout ;
http://www.sherbourn.com/collections/theater/products/pt7030 with a 40% off card for future emo pre pro 's smile.gif
post #8 of 12
I used to be a fan OF some Emotiva stuff I like /own some of their amp but processor wise had nightmares with umc-1 and aparently that 7030 is going the same way
Dan
post #9 of 12
Dan
Happy with mine Dan ; some dont like the osd gui [its not an overlay but its easy and set and forget if you prefer that ] . Mines been solid as a rock after traveling across the pacific . Glad I didn't have a umc1 as the bass management and emoq on that cirrus logic chip - you know eek.gif
The 7030 was designed for the CI market where installers require solid performance and is quite stable I find [ as was the umc200 I ran before it [ not so much the cary11a before them though - at least in the 1st firmware iterations wink.gif ; otherwise one thing that is a negative is the lock on time for hdmi;spdif . The 1st second of music may mute but there is a firmware being worked on that addresses this thankfully .
Another way of looking at it is it's going to be continued as a emotiva model but that won't be this price and if it weren't up to it it's a perfect chance to cut losses and drop it .. There's the xmc1 and rmc1 to fill out the line smile.gif
post #10 of 12
yeah i know about the upgrade card, i already have two... and im going to get a xmc 1 to see if the stuff has been better.... but ill pass on the 7030....for this moments, tks for your comments..
daniel
post #11 of 12
daniel
No problem ; my plan was to wait for the xmc1 too and if I had the 40% off card I would have waited ; now out of the blue emo gives me one after the fact for buying the 7030 ; the rmc1 may be looking better now rolleyes.gif
post #12 of 12
Yamaha 2030.
