AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Small foot print AV Receiver Needed
post #1 of 5
I am searching for a unit that is no deeper then 12" to fit in my motorhome. I would prefer it to be slim line as well 3-4 inches, but not a deal breaker. I was interested in the Sherwood N-904N and did not care about the VuNow being bad. Just really liked the size, but the manual did nto list Vizio as a supported TV code,.
Anyone with any help would be appreciated. Thanks
post #2 of 5
Check out the H/K AVR 1510, 1610 or 1710. They are just under 12" deep at 11 13/16".
Crisp'N'Clean
post #3 of 5
Thanks...I will check it out.
post #4 of 5
Not sure how deep the Marantz slimline receivers are, but they're pretty short in height. Yamaha also has the S600.
post #5 of 5
Depending on what your needs are, the new high-fidelity but small footprint integrated amps are intriguing. Here's a link to the Teac A-H01:
http://www.teac.com/product/a-h01/
