AVS › AVS Forum › HDTV › HDTV Technical › Comcast HD box-Flickering on premium channels
post #1 of 3
Comcast HD box to a 60 in. LG plasma, flickering on premium channels only, called once and they reset,ok for a day, now flickering again, is the box bad, maybe the HDMI hook-up? Called comcast last-nite, not much help, rolleyes.gif Why only the premium channels and not the others??
post #2 of 3
It could be a weak signal to the box. Generally, cable companies give premium channels a bit more bandwidth to make them look better, and if the signal is low, that could cause it. However, if the signal is low, it would usually get blocky, not flicker.
I would say it's most likely a bad box. They go out a lot, at least the motorola ones that my cable company gives out do.
post #3 of 3
  Back to Forum: HDTV Technical
