AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › picture issues benq w1070
post #1 of 4
I just bought the benq w1070 for my living room. Everything went up great and then i turned on the pj...the top of the image is level and the rest is slanted to the left side toward the top...ive been fidgeting around for the better part of 2 hours now with no luck....any suggestions? 20131026_161936.jpg 1069k .jpg file
20131026_160925.jpg 1063k .jpg file
I tried to search the issue but in my rather frustrated frane of mind i decided to post instead. Thanks
post #2 of 4
your projector is not square with the screen.
rotate it left then right you will see how it alters the image..
post #3 of 4
I just got mine. Were you able to correct the issue? I'm having the same problem. Moving my projector left and right doesn't fix the issue.
post #4 of 4
Welcome to the forum. I would suggest that you post these questions in the regular thread. No need to start a new thread with every question.
The projector is not set up correctly. You don't say how it is mounted but it is not even with the screen. That is the reason for the test pattern. Try moving the projector slightly on each side from front to back. You may also want to measure the distance from the projector on each side. Being off by a slight amount will cause this issue.
