AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung Smart TV's - What codecs are supported? Trying to open Widi DLNA desktop stream on tv
post #1 of 3
For those of you not familiar, intel has its own WIDI (wireless display) technology where you can stream your desktop with full quality and low latency.
Unfortunately you needed an external Widi compatible adapter or TV, which I believe the Samsung 8000 series have support for.
I looked into widi technology since I do not keep wanting to use an HDMI cable to connect my laptop.
I found out that with their new software update, WIDI can now stream regular DLNA devices but with the fact that it takes a hit with reduced quality, 720p, and higher latency.
I got it setup and unfortunately my samsung tv is stubborn and doesn't want to accept the input. (es7000) i believe.
Yet on youtube I saw another person using a samsung TV with intels DLNA WIDI stream.
http://www.youtube.com/watch?v=3dSzEk_OWGk
I managed to open the DLNA stream on my computer to evaulate the codec and am trying to pinpoin the problem. Is this codec not supported, or is the problem somewhere else in my setup?
Here is the codec info:
Stream 0
Type: Audio
Original ID: 4352
Codec: MPEG AAC Audio (mp4a)
Channels: Stereo
Sample rate: 48000 Hz
Stream 1
Type: Video
Original ID: 4113
Codec: H264 - MPEG AVC (part 10) (h264)
Resolution: 1280 x 720
Frame rate: 60
Decoded format: Planar 4:2:0 YUV
Does samsung not accept these codecs?
post #2 of 3
Here is additional information I found about the media source
General
Complete name : C:\Users\Olivia\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\YBNVXCY6\Intel(R)_WiDi[1].mpeg
Format : MPEG-TS
File size : 2.06 MiB
Duration : 7s 168ms
Overall bit rate mode : Variable
Overall bit rate : 2 411 Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=15
Codec ID : 27
Duration : 6s 183ms
Bit rate mode : Constant
Nominal bit rate : 3 000 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.109
Audio
Menu ID : 1 (0x1)
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 2
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Duration : 7s 168ms
Bit rate mode : Variable
Channel count : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -22h 59mn
post #3 of 3
To use intels widi... The tv must have: Widi built-in or a widi reciever box connected to the tv with hdmi cable.
Next your computer needs a Intel cpu, Intel gpu.
This video from youtube will explain:
http://www.youtube.com/watch?v=j0PQVowC-ow
Hope it helps :-)
