AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › Best signal output option for quality.
post #1 of 16
I have a DCT6200/2005 cable box with Comcast. It has DVI, RCA, and component outputs, even the coaxial output. I have a Pioneer SC-1222K receiver I would like to know which of the above options is my best options for image quality and sound. Also for audio I think it has an optical out. At first I wanted to grab the DVI output and use an HDMI adapter but then I thought maybe the cable box with try to upscale or something and maybe the Pioneer has a better scalar. But then I realized I am out of my league on that decision.
post #2 of 16
Hey, best bet for what you got is component cables and optical audio... No delay's and 5.1 Dolby... Good luck wink.gif
post #3 of 16
I am unable to get the component out to work, is there any setting on the set top box that I need to set? Also does it matter if I do not have an HD plan with Comcast? The optical audio is working OK though.
post #4 of 16
do you see any video when using the component outputs (blue screen) or do you get the no signal message from your tV?
post #5 of 16
I only get a black screen, IE nothing. no no signal message, no color at all.
post #6 of 16
Direct to the TV, through the receiver or both?
BTW.... what is the make/model of the TV?
post #7 of 16
It is going into the receiver I have not gone directly to the TV as I do not have cables that long yet. The TV is a TC-P54S1 I think (going off memory) early base model Panasonic plasma. It is being fed through HDMI port 2 from the receiver. On the pioneer I am using the BDR/DVDR port for optical and component. I don't know if this is any evidence but if I simply move over one of the cables to the yellow video out RCA port on the receiver and the cable box it works fine along side the optical audio. But I cannot find any place in the recievers menus that would let me force it to component over the yellow RCA jack.
post #8 of 16
Your wekest link is probably the source, the cable TV feed. I don't think it will matter much what kind of wires you use or connections, you simply can not make 720p look like 1080p with just wires, same for sound.
post #9 of 16
Yeah... but 720p or 1080i looks better than 480i and since you can't get higher resolutions over an (analog) RF or composite connection/wire, it does make a difference. wink.gif
post #10 of 16
You have Component and Optical from the STB to the receiver and HDMI from the receiver to the TV.
The audio gets through but no video.
I found the manual and there is a setting on the receiver to allow all video sources to pass via HDMI.
Video Parameter Menu (on or off).
If this is turned on and no video I would try to bypass the receiver or see if you can swap out your box for one with HDMI.
post #11 of 16
Originally Posted by RCbridge View Post
... or see if you can swap out your box for one with HDMI.
Or just use a DVI to HDMI adapter.
post #12 of 16
Strange, when I connect the XBOX over HDMI or YPBPR component I can't tell the difference. And the TV still "says" it is 1080p. Probably because Component video (unlike Composite) is capable of carrying up to 1080p resolution video signal.
post #13 of 16
Start from the 1st post and carefully read the entire thread. It's not about component vs. HDMI.
post #14 of 16
And my point is that best possibly signal paths already exist without the need for converters and adapters, and the limitng facor is the signal source it self.
If the broadcast is in 480i, there is nothing OP can do to magically make it 1080p.
Component video goes to the TV, and coax audio goes to the AVR. If AVR does not support coax, or the box is only capable of outputting stereo, then that is all OP has, other than AVR's dolby pro logic, or Neo 6 capabilities, if present.
post #15 of 16
Again.... re-re-read all of the OP's posts.
1) he has an older STB with DVI.
2) has an AVR connected to the TV via HDMI for video.
3) he is using optical from the STB to AVR. That works just dandy.
4) he is unable to get video when using component from the STB through the AVR to the TV (a signal path)
5) he doesn't have component cables to go directly to the TV to test.
6) he only mentioned that composite works from STB through the AVR to the TV
So....... the suggestions have been:
DVI to HDMI adapter
New STB with HDMI
Try to figure out why the component connection doesn't work. (is it the TV, STB, AVR and/or setup options in one of the aforementioned devices?)
I think everyone is aware that the cable provider can/does broadcast 480i, 720p and 1080i and PQ may vary. But, that's another discussion.
Well... yes and no. What option/device is best for upscaling?
Let the AVR upscale to 1080p?
Let the AVR send natively to the TV and let the TV upscale to 1080p?
True that with 480i, you can't make a silk purse from a sow's ear, but with 720p/1080i magic can happen. biggrin.gif
post #16 of 16
Did the OP ensure that the receiver function (Video Parameter Menu (on or off).)
Is set to on, if I read the manual correctly the receiver won't convert the video via HDMI if it is not set.
  Back to Forum: Cable, Digital Cable - Non-HDTV
