AVS › AVS Forum › A/V Control & Automation › Remote Control Area › IR codes for Yamaha HTR 6190 and 6160
post #1 of 3
Hi,
Does anyone have the IR codes for Yamaha HTR-6190 and HTR-6160 receivers?
post #2 of 3
Here is a link to remotecentral it is a zip file that has hex code witch is ir code in numbers and letters. All universal remote will let you enter this code for each command it is just time consuming. Hope this helped.
http://files.remotecentral.com/view/2449-4755-1/yamaha_rx-v1800_receiver.html
post #3 of 3
Thanks a lot
  Back to Forum: Remote Control Area
