AVS › AVS Forum › Audio › Speakers › What would be a great set of speakers for
post #1 of 10
A home theater 5.1, bookshelf speakers
For watching movies and sports
For a room size of 30 feet x 14 feet
What would be your recommendation for this price range?
My budget is around $1300
post #2 of 10
Welcome to the forums. I notice you have the same post in the HTIB forum. Do you want a recommendation here for speakers & sub alone? No receiver, dvd/blu-ray player as with a typical HTIB?
post #3 of 10
I would appreciate a recommendation for speakers + sub + receiver
Thank you
post #4 of 10
Denon AVR-1913
SVS PB-1000
(4) Pioneer BS22
Pioneer C22
post #5 of 10
Originally Posted by Transmaniacon View Post
Denon AVR-1913
SVS PB-1000
(4) Pioneer BS22
Pioneer C22
+1
post #6 of 10
Some else suggested that I add these information as well
I dont have any speakers currently and just use the speakers from the Samsung TV which I got last year
The TV has HDMI and analog outlets
Dont need ipod connections. Just need to connect to the TV and the DVD player.
For a cable connection
Bookshelf speakers is what I am looking for
I would need recommendation in speakers + receiver
The room is prewired for 5.1 bookshelf speakers
My listening habits are 80% Movies/TV/Sports and 20% pop music.
post #7 of 10
fwiw, just another suggestion; home theater direct level 2 speakers
denon avr 1713 refurb. ac4l
svs pb-1000 or rythmik lv12r sub
post #8 of 10
OP - ac4l translates in English to accessories4less.com for a refurbished avr (still with warranty) smile.gif
All good suggestions so far, unless you want to up your budget....
post #9 of 10
Try looking at NHT super zero's for your main and surround speakers with their subs sound great and u can still afford a nice little Denon to power them.
post #10 of 10
As nice as I think the SZs are (I run 5 of them) they are too small for that room unless the OP's MLP is pretty close, like 9ft or less.
  Back to Forum: Speakers
