AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Super Noob needs help choosing LCD
post #1 of 6
1. Budget
maximum $1400 including taxes
2. Seating Distance
7-10 feet
3. Size/placement limitations
50" or 55"
4. Uses and sources
cable (mix of HD and SD), sports events,blu rays from htpc (must be able to handle 1080p/24 properly without judder/problems)
5. Room lighting
In basement, lighting not really a problem. Some pot lights on sometimes, mostly dark.
I'm thinking I need a 120hz for proper blu ray playback correct, 60hz won't work?
These are the ones I'm looking at currently, any other suggestions welcome:
Sony 50" 1080p 120Hz 3D LED Smart TV (KDL50R550A) - [URL=http://www.futureshop.ca/en-CA/product/sony-sony-50-1080p-120hz-3d-led-smart-tv-kdl50r550a-kdl50r550a/10245473.aspx?path=5e9ad8befb6bb0d748f17ef370c573f7en02[/URL]
Samsung 50" 1080p 120Hz LED Smart TV (UN50F6300AFXZC) - Web Only - [URL=http://www.futureshop.ca/en-CA/product/samsung-samsung-50-1080p-120hz-led-smart-tv-un50f6300afxzc-un50f6300afxzc/10243932.aspx?path=849604be7e61aca6b6a5988380653648en02[/URL]
Panasonic 50" 1080p 120Hz LED Smart TV (TCL50E60)- [URL=http://www.futureshop.ca/en-CA/product/panasonic-panasonic-50-1080p-120hz-led-smart-tv-tcl50e60-tcl50e60/10242939.aspx?path=3bc2633fd4a461e294a9dfb7142bb66den02[/URL]
LG 55" 1080p 120Hz LED Smart TV (55LN5700) - Future Shop Exclusive-[URL=http://www.futureshop.ca/en-CA/product/lg-electronics-lg-55-1080p-120hz-led-smart-tv-55ln5700-future-shop-exclusive-55ln5700/10243607.aspx?path=a9b621cd99a0442fa6394638a202ea01en02[/URL
post #2 of 6
IMO, think you should save a little more and a buy Plasma.....
post #3 of 6
i bought a plasma and returned it. want an lcd.
post #4 of 6
still looking for suggestions.
post #5 of 6
I posted in the "what lcd should i buy" thread a few days ago and didn't get a reponse thats why i made a seperate thread. maybe i need to make a post in each of tv's threads above.
post #6 of 6
