AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › xbox one HDMI issue?
post #1 of 5
Hey guys a quick question for anyone here, I read online that the new Xbox one will not have the option to connect component cables. This being said im not sure if I should do a new HDMI cable run into my ceiling to the projector or if there is a HDMI to Component converter I can use. Any suggestions? Or should I just go in and replace all my lines from component to HDMI for all my other accessories, i.e. TV, 360, ps3?
post #2 of 5
Do you own an AVR? Why not buy one that can switch your source with only one HDMI cable to your projector. If you're running a projector I would hope you have a surround setup.
post #3 of 5
yea I have an ONKYO 7*** model, Just dont know how easy the run will be , its in my basement and cable runs through ceiling down to front left of projector screen.
post #4 of 5
I would think the investment would be worth it to add more lines for HDMI for the future products you have coming into the home.
post #5 of 5
Yea your right man, I guess I will lock myself in my basement this weekend and run the cable through, hopefully its easy enough. Might use one of the existing component cables as my pull string.
  Back to Forum: Xbox Area
