AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › HTPC Gaming › The official AVS "PC Game Console" thread
The official AVS "PC Game Console" thread - Page 13
post #361 of 429
Back to the ON/OFF solution.
While the HP sensor will indeed put the PC to sleep, I still have the blinking sleep led. Annoying. Found this device and ordered it, http://www.simerec.com/PCS-1a.html . This uses a standby voltage feed from the power supply and an IR sensor to receive the remote signal. Has anyone use this with a Logitech Harmony 700 or similar?????????
Thanks in advance,
post #362 of 429
Thanks in advance,
Well, the remote will only put it in and out of sleep mode.  If you actually want to turn off the sleep LED, just open the case up and pull out the cable for it. Some PCs have a separate lead for the sleep, some just blink the power....in that case, you'll just have to pull the cable for the power, although you wont know when its on or off.
post #363 of 429
There web site seems to indicate this is a complete on/off solution and still retains the case on/off switch. Some Utube videos seems to indicate that also?
Again, not trying to be contrary. Well, it's ordered and I will report back. I'll use the MCE computer type on the 700 and test the on/off button. More later.
post #364 of 429
Yeah, but then you've gotta cold boot the system every time.
post #365 of 429
Yes, I agree. I don't use this PC daily and the blinking light drives me NUTS, ha.
Gives me more to think about. Old geezers like me (nearly 71) need the challenges, ha.
post #366 of 429
Get some of those little light dims, stick it on and be done.
post #367 of 429
For those of you who signed up for the Titanfall Beta on PC before the 15th of this month...you are IN!
I have it downloading right now and will report what I think of the game.
Also, if you have an Xbox One you are also automatically in the beta as well.
post #368 of 429
A Titianfall PC thread has been created...http://www.avsforum.com/t/1518388/titanfall-pc
post #369 of 429
Thanks, I honestly didnt even bother to look for one...am going to go post some thoughts over there right now.
post #370 of 429
Alright, finished my 1st build...well, almost. The gpu arrived today and the rest is up and running. I'll install it this week when I have some time. Here are the components, pictures to follow when GPU is installed:
http://pcpartpicker.com/user/Justasheep/saved/3WBE
I had a friend contribute the H100i and the Corsair fans as well as his time to help me put it together. That's why the costs for those items are $0. I feel I did pretty good on the budget and this machine should last years with minor improvements/expansion. I can't wait to sit back on the couch in the home theater and crank up a good game! Thanks to all those who contributed to this thread.
post #371 of 429
Nice build man! Really solid. Should handle nearly everything maxed out @1080p
post #372 of 429
Yes, that looks like a very solid build. The GTX 770 is about the best your can do as far as performance per dollar spent right now...only thing that could throw it off would be a 780 with their prices going down right now....but wait a few months and when the 770 drops in price some more and then maybe grab another 770 and run them in SLI...
post #373 of 429
Thanks all. Yeah, I agonized most over the GPU due to costs. They are way higher proportionally compared to last time I bought/updated a PC. It was tough knowing how inflated they are now. I was also torn between the 2gb and 4gb versions. I will never do multiple-displays while gaming and so far am unimpressed with 3D, so I don't know if I'll need the 4gb. As long as games don't exceed 2gb in the near future, it should be fine. Also wasn't sure if SLI would be better served with the 4gb headroom. We'll see. I do plan to pick up another card before making any other major changes.
The GPU is installed now, btw. Just finished updating drivers. Audio wasn't coming through the hdmi, so may have a bios setting to change, not sure yet.
Thanks again,
Sheep
PS: Thinking about Bioshock Infinite as first game to play on this machine. Also pretty interested in the DayZ standalone.
post #374 of 429
Thanks again,
Sheep
Play BI first. Play DayZ SA but don't expect good performance, it's still Alpha, and not optimized so don't use it as a gauge for your rig's performance
post #375 of 429
I think you are on the right track - go into the motherboard's BIOS and disable on-board audio. Then when you get back to Windows, if you are still not getting audio, check in Nvidia's control panel (right click on desktop), there's a digital audio option there.
post #376 of 429
Yeah, it was just that I hadn't finished updating the nvidia drivers yet. I did change the bios to send the HD Audio to the spdif instead of hdmi, but I think the issue was the nvidia controllers weren't present yet. I don't know if anyone here has tried using Intel audio on a Haswell rig, but good luck to you if you do (w/o a sound/video card). Even when you are able to get audio, there's something not right w/ the stream.
I think I will do BI as I've played the series on the 360 so it will be a good point of reference. I like the concept of DayZ but I'm afraid this round will be just a novelty and the next gen will be the real deal.
post #377 of 429
Don't forget to check the sound control panel.
post #378 of 429
Skyrim with graphics mods is also great to push the limits of your system.
post #379 of 429
I'll bet Skyrim looks great. I've seen some pics. I've played it for many hours on the 360, though, so might not go back to it.
Edited by JustaSheep - 3/5/14 at 7:46am
post #380 of 429
gotcha.
Well the other games that could really push the limits graphics wise that I can think of off the top of my head are Battlefield 3 and 4.
post #381 of 429
gotcha.
Yes, I will get to those eventually. Played BF3 on the 360, but will play BF4. I first want to do a comp by looking at BI on both setups.
post #382 of 429
The most obvious switch going from Xbox 360 to PC is you'll gain 1080p 60fps on just about everything. There will be some extra effects too depending on the game, which may or may not be as noticeable, but if just for bumping up to 1080p/60 I think you'll be pleased with the upgrade.
Will you be PC gaming on a X360 controller?
post #383 of 429
I agree with DaverJ, the bump in resolution alone can make a big change.
Do you like strategy games? Those can certainly flex some PC muscle as well through the simple scale of it. I have had games of Civ5 that are simply huge!
Total War Rome 2 could be a good one to look at as the graphics and scale are simply amazing. I have not played it at all yet but it's on my list.
P.S. South Park: The Stick of Truth is getting some really good reviews and can be played with a 360 controller
post #384 of 429
Watched Marafice play the first few hours of South Park. If you are a fan of the show or their other works then you would love the game. Not sure if it's worth the $60 because I feel like there will be little replay value BUT if you're Marafice Eye then it IS worth $60. There, saved you from having to post, Dan. wink.giftongue.gif
I'm having fun watching it. We are recording the playthrough with us doing audio commentary. Not sure when Marafice with have those recordings available to the public.
post #385 of 429
Yeah, can't wait to see the differences. I like console gaming but miss the smoothness and responsiveness of a fast PC. I will game with either, controller or mouse/keyboard. It's been a while since I've not used a controller though, so I'll lean towards those games.
I do like strategy games, but prefer turnbased games to RTS, i.e., I'm old and slow. smile.gif
Cool, I will keep it in mind.
Edited by JustaSheep - 3/5/14 at 12:35pm
post #386 of 429
if you are into turn based strategy then I dont think there is anything better than Civ5 in my opinion. I have a couple of the expansions for it as well but one of the expansions that I dont have added DirectX 11 support which should increase the graphics performance by a decent amount.
I never buy a game new...but South Park will be on sale for the summer sale in a few months probably for 25% off atleast.
post #387 of 429
The Metro games seem to be pretty graphically punishing. Also fun as hell!
post #388 of 429
You can get it for 25% off right now on GMG, for another 1day and 13 hours so get on it.
http://blog.playfire.com/2014/03/25-off-south-park-stick-of-truth.html#more
post #389 of 429
So I've been working on a little utility to make couch PC gaming way easier with just a controller. Right now, I've got it working where you can hit a button combo to enable mouse emulation on the gamepad, and a way to toggle steam big picture on/off. Still a little buggy though!
The mouse emulation turns the left stick into mouse control, A/B buttons into clicks, and the d-pad into scrolling/mouse wheel. Makes it super easy to deal with those launchers.
So I'm prob going to add a way to alt-tab, close a game, and maybe an on-screen keyboard. I've also got it sending F12 to toggle the MSI afterburner OSD for performance monitoring.
Anything else you guys can think of that would be useful? Once I work a few bugs out I'll release it. smile.gif
Edited by bd2003 - 3/8/14 at 4:06pm
post #390 of 429
Great Thread. I have a "gaming" laptop, a couple years old, but still quite good, which I plan to plug into my Denon x4000 via HDMI and test out some games. I also found this list which may come in handy:
PC Games with Xbox 360 Controller Support
EDIT - Any hints on games that sound great on a 7.2 system? I am not interested in shooter games, but rather racing, adventure, sports, etc...
Edited by McStyvie - 4/8/14 at 5:32am
  Back to Forum: HTPC Gaming
