AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pio SC-1222 jumps out of PCM...
post #1 of 6
Hello Audio Experts!
We tried to watch a movie last night, but the SC-1222-k kept jumping out of PCM & into stereo every minute to few minutes, for a duration of ~ 1-5 seconds. This would cause a loss of sound & pop in the speakers, & loss of picture on the longer intervals into stereo. I checked all the wires this morning, but they are fine. Pio is closed until Monday so I can't speak with them now.
Any ideas, pls?
TIA! Murf
post #2 of 6
Could it be the disc? Did you try another disc?
post #3 of 6
Yes, I tried two disks, but now that you mention it, both were from Netflix. I better try another....
Should I try to reset my microprocessor, like is in your sig?
Thanks, Murf
Edited by vanguardtm - 11/3/13 at 8:12am
post #4 of 6
That would be the final step as it would reset all settings to their mfr defaults. First rule out it's not an issue with Netflix.
post #5 of 6
The Pioneer help line came through for me. Right away they suggested that it was the HDMI cable from the receiver to the TV. As a second, they said there was a small chance that it was the HDMI cable from the DVD player to the receiver. This second one was it. I bought a couple of cheap HDMI cables off of Ebay a while back, so be warned!
Thanks, Murf
post #6 of 6
Murf ,ive been having the exact same problem with my 1222k! But mine will do this if im usong c.d, radio! Hasnt on Netflix movies! Please let me no what u found out????? Dabsim
