AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Subwoofer Preamp?
Subwoofer Preamp?
post #1 of 4
Ok.
I have been looking for a dedicated Subwoofer Preamp. Something like a Plate amplifier you find on the back of powered subs but only the preamp section. This way I can use whatever amp I have and any sub. I have several amps and several sub drivers. I like to experiment with enclosures and different drivers. If I had a small Subwoofer preamp then I could rotate amps and subs with the capability and flexibility of adjustment from my listening position (with a nice long rca cable of course). Is there such a thing? Something with level, phase, crossover, eq, controls and all the other fancy stuff?????
post #2 of 4
Nothing????anybody out there??????.........
post #3 of 4
Elemental Designs eQ.2 sorta fits the Hill although no lowpass filter. Not an issue if you're using an AVR as you'll use it.
post #4 of 4
Thanks for the reply. I was starting to think there was no one out there......biggrin.gif I will check it out.
