AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Which cheap-ish receiver will accomplish this?
post #1 of 2
I have some speaker throughout my house, and I have a couple on my porch. The wires all come out behind TV. I have a DVD player, a VCR (yes, a VCR), am HD Dish Receiver, and a TV. I want to have the ability to listen to music on the TV and send it to the two speakers outside. On top of this, is it possible to send two difference sources to two different locations?
Anyway, this is not a primary entertainment thing. I need it to be reliable and suit my needs, but the cheaper the better.
What should I go with?
post #2 of 2
Are there any receivers in the 200 or less range that will handle AV 5.1, airplay, and have a powered zone 2?
