AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Does a row of 3 decent theater seats exsist for $1,200?
post #1 of 6
I'm looking for a set of decent (3 seats) seats for around 1,200. Can you guys point me in the right direction or does this not exist?
post #2 of 6
What is decent in your understanding?
What are you looking to have in the seats?
Features, cover, dimensions, etc...
There are so many things needs to be considered in choosing a proper seat.
You will have to cut corners if the price is your only criteria...
post #3 of 6
Pops up from time to time. They are usually manual recline, like the now defunct K-Mart ones.
If you can wait a couple of months, COSTCO usually has a furniture event right after Christmas. The past few years have included theater recliners in that price range.
I'd still talk to Roman or Ken Lerch though. You will be happier in the long run.
post #4 of 6
Manual is fine. I don't need any bells and whistles. I just want something that's going to last and is comfortable.
post #5 of 6
Air Supply,
Here are some models to consider:
* Palliser Pacifico in Fabric/Urethane cover called Phoenix (feels like leather/suede but is actually fabric and polyurethane blend)
* Albany Casablanca
* Albany 8630
post #6 of 6
Nevermind, I decided to go with the Fusion Tributes.
