AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Sony STR-DN840 or Sony STR-DN1030 only for WIFI and VTUNER
post #1 of 5
I have a Older Yamaha RX-V867 with Network that's working well in Living room.
Anyways looking to get a New Sony,Pioneer or Onkyo for my Bedroom that I will only use for a 37 inch Lcd Tv and a Old Nitendo and want to Have Wifi so I can Listen to Vtuner at night while trying to go to sleep.(people leave their Tv on for falling asleep but I rather listen to a radio}
I have Been using a GRACE Internet radio with Wifi that cost me $175 about 2 years ago but feel maybe using a High end Sony with Wifi will make it a lot better to fall asleep instead of using the Porable Grace radio.
My problem
I know I can buy a New Pioneer VSX-822-K for $189 and another$30 for the No Name wireless link to be able to get onto my wireless router.
But I feel maybe its best to spend a bit more and get a
The Sony DN840 is going for $450 while the
Sony DN1030 is $424 with Tax from Costco
I know that the Sony DN1030 is a little older then the DN840 but $25 is not a
problem if I get the DN840.
For some reason I am leaning towards the DN1030 thinking its atad better then the DN830?......Thanks JT
post #2 of 5
post #3 of 5
after reading the spec on the 840, it sounds like it will do what you want.
the 1030 is the old one replaced by the 1040/ the 4K TV pass through.
just about the only difference is power out, and the new 840 is 4K TV pass through.
post #4 of 5
Thanks for the good advise in getting the DN840 ( think they all do what I want since I am not doing much other then listening to Vturner,Thats my hope}
Yep I know that the DN1030 and DN1040 are kinda the same except a few little items
like the 4K and the $175 extra for the DN1040.
I like the Price of the DN1030 for $424 even if its only 8 - 12 months older?
I like having a Receiver with a Wifi built in to listen to Vtuner.
Seems the DN840 has been around $450 for awhile?And the DN1030 has been getting cheaper?
Maybe its best to wait a week or two too seen if there will be a price drop on
these since Black Fri will be here(don't mind buying the receivers now but with holidays prices should go lower lol}.Thanks........JT
post #5 of 5
Going to get a Sony STR-DN840 for $399
Was going to buy a Onkyo TX-NR626 for $444 but it does NOT have Vtuner but a service called Tunein and Tunein does not get as many radio stations as the Vtuner does.(Not Good}
But for $399 I feel that this receiver will not get too much lower(well maybe a little lower for the holidays}.........JT
