AVS › AVS Forum › HDTV › HDTV Recorders › Philips HDR5710/5750 DVRs, Antenna/Cable, Wired/Wireless Streaming, 33TB Storage
Philips HDR5710/5750 DVRs, Antenna/Cable, Wired/Wireless Streaming, 33TB Storage - Page 16
post #451 of 559
Originally Posted by michgpan View Post
Dvr quirk ?
Hi guys,
I have owned my dvr since before xmas and we love it.
No real issue. Great audio and video !
What i noticed once was seeing the dvr act weird.
It powered down by itself when a recording was commanded to play.
The wife noticed this and called me over.
I was puzzled.
Here is what i found solved the issue.
Since then no issue.
I found that the dvr was trying to tune into a false channel in memory.
i switched channels and the tuner displayed all good channels with no issues.
Except for a 1 channel.
That channel was 2.0 .
Not sure why this channel appeared in my list.
Btw...Kids and wife use the dvr.
I went into the menu and set these channels to skip.
They never reappear any more.
And the quirky operation is gone.
Mp
FWIW:
Where are you located?
Channel 2.0 should be analog. It could be a low power channel which can still be analog.
The DVR may not like analog channels.
Above is speculation.
post #452 of 559
Dvr quirk ?
I was puzzled.
If that ch. 2.0 is analog, the DVR should be able to tune it, just not record it... unless it's a weak channel, which might cause problems? The DVR has a "special" ch scan option for "Weak Channels" which is interesting and might mean the unit does something "special" to tune weak channels... it would be nice to know why weak channels got their own scan option... mechanically/electronically speaking..
Otherwise, do you have Auto Clock on and a known good channel set. I'm wondering if the time search might have something to do with populating the channels it might find if the channel entered doesn't have a time signal at a particular time so it searches all channels instead? This is a SWAG (Scientific Wild Ass Guess), of course.
post #453 of 559
Originally Posted by Mtl77 View Post
Hi,
I received the DVR two weeks ago.
i had no issue with initial setup (OTA, digital channels only)
Everything works perfectly exept when using timer programming. Once in a while i get a title that won't play (not even in the preview thumbnail, and not in full screen play). All i get is a black screen, then a frozen DVR and after something like 30seconds to 1 minute, the DVR reboots.... When it does i can hear the internal hard drive stopping abruptly
After reboot the DVR is responsive, unless i try to play the same corrupted title (i get the same black screen of death and reboot)
I am able to delete the title
Direct recording always works. The problem i described above is with timer recording only, and is intermitent. i tried to find a patern (what's causing this), no luck so far.
I have a feeling it's a firmware issue (i have the latest version)
Has anybody seen this?
I had the same issue too in the beginning, but I changed something in the configs and the problem went away. I do not remember what I changed so you might want to play with a few settings. One other thing to try is always press the stop button twice when you are done watching something.
post #454 of 559
Originally Posted by videobruce View Post
Regarding discovering the particulars of the partitioning and format of the drive, has anyone connected it to a PC then run a program outside of Windows to discover any details with these drives?
Three examples are (all free);
Parted Magic V8,
Hirens Boot CD,
Ultimate Boot CD
There is also GParted, but it has a serious bug error message when reading drives with a GPT partition table. There also numerous other programs that you boot to outside of Windows (using a USB stick or a CD). I would think at least one of those would shed more light on the subject.
Using GParted the drive is formatted in the XFS file system
post #455 of 559
Parted Magic was not what I wanted to say. GParted has issues with ID'ing file structures which is what is included with PM.. MiniTool Partition Wizard (also free) was it. It's the best partition program I have used in years. It recognizes GPT drives and confirms the file structure. I've been able to 'see' drives that other programs do not.
post #456 of 559
Hi.
Yes its a analog channel.
And, i set it to skip.
A few other channels were set to skip for preference too. (music only or french)
Btw, i live in the niagara buffalo area.
Thx
Michael
post #457 of 559
Hi.
Thx
Michael
I wonder if 2.0 will be a problem since WGRZ is channels 2.1 (virtual) from physical channel 33. I can't duplicate this problem.
post #458 of 559
Did you see my Auto Clock question in post #453?
post #459 of 559
Thanks, will try to play with settings.
Are you using an external hard drive (i am not, and i was wondering if this could change anything to my problem)
post #460 of 559
Hi,
Im set to virtual 41.1 global for time.
No issues.
michael
post #461 of 559
That would be the only logical explanation. Some weird glitch.
Does WIVB get ID'ed as 4.1 or 39.5?
post #462 of 559
:D
Dizzie2 reports (in the Mag SD 53X thread) that Amazon is selling the 5750 for $258.99, only $9 more than the 5710.
:D
post #463 of 559
wajo, Thanks, as usual, for steering me to the right thread. I get lost so easily. wink.gif Amazon also has free shipping.
Currently Best Buy has the 5750 for $279.99 but I did not check to see if they were available in stores. I placed my order with Amazon.
post #464 of 559
That $258 Amazon price only lasted a few hours!
post #465 of 559
That is one of the things I do not like about Amazon. They change prices frequently and sometimes dramatically. That is why I ordered a unit immediately when I saw the price had dropped. It has already been shipped.
post #466 of 559
As always WAJO this is an excellent post.
Sadly the 5710 /5750 are very limited devices:
No Inputs (HD or SD).
No Cable Card slot.
Single tuner.
Can't support QAM.
Limited NTSC compatibility.
Don't have support of other standars like DVB-T2.
Don't have buffer recording (Yet).
Can't recording using a guide (Yet).
Can't record from analog chanels.
Can't edit a single title.
Can't export watcheable recordings.
Can't play Blu Ray discs.
Don't came with a fee mobile app.
And the worst of all, are overpriced in $150..., because $258 for those bricks is a joke. ($99 wil do the trick)
So as the others said, this round is for the iView.
Edited by profhat - 2/1/14 at 12:45pm
post #467 of 559
Can't support QAM.
So post #1 is wrong?
post #468 of 559
Can't support QAM.
No, I failed to put the word "QAM" anywhere. Fixed now. (I ass-u-med everyone knew that cable uses QAM.)
post #469 of 559
Posted list of negatives with my notes (opinion) on each.
No Inputs (HD or SD).... True.
No Cable Card slot.... True.
Single tuner.... True.
Can't support QAM.... False.
Limited NTSC compatibility.... ??? Tunes NTSC/analog, just can't record analog. Can tune and record ATSC (OTA) and Cable-QAM.
Don't have support of other standars like DVB-T2.... True.
Don't have buffer recording (Yet).... True.
Can't recording using a guide (Yet).... True.
Can't record from analog chanels.... True. Tunes them but can't record them.
Can't edit a single title.... True if this means on Philips itself. Can real-time-copy to DVDR/PC for editing. Working on file-level transfer to PC. Baby step by Linux newbie: got USB-HDD files to Windows PC. Just discovered USB-HDD file system type: XFS. We need "expert" Linus/XFS help.
Can't export watcheable recordings.... Not now but working on it. Baby step by Linux newbie: got USB-HDD files to Windows PC. Just discovered USB-HDD file system type: XFS. We need "expert" Linus/XFS help.
Can't play Blu Ray discs.... True.
Don't came with a fee mobile app.... True.
And the worst of all, are overpriced in $150..., because $258 for those bricks is a joke. ($99 wil do the trick).... An opinion.
So as the others said, this round is for the iView.... Another opinion.
Edited by wajo - 2/3/14 at 7:51am
post #470 of 559
post #471 of 559
Hi,
Like you mwg1 i got rid of this problem after i played with the settings. And like you i cannot say what is it that i changed that solved the problem
There is definitely something wrong in the original settings. Convinced more than ever that it is a firmware issue
Everything works well now
Thanks a lot mwg1
post #472 of 559
Mtl77, No other reports like yours, either here or on other sites, so no help there
Does the problem occur on one or two specific channels and no others (e.g., an ION channel)?
Are your black screens throughout the entire recordings or just sections of them (you'd have to review the entire recording)?
hi Wajo,
Mwg1 had the same issue, and suggested that i play with the settings. Which i did and the problem went away. See my last post.
The problem was not channel specific
And yes the black screen was throughout the entire recording. Actually the screen would go black immediately at the begining of the playback and then the dvr becomes non responsive.
post #473 of 559
hi Wajo,
I wish one of you could remember the setting changes you made. Without that, we'd just be guessing on a setting connection to this problem.
Are both of you OTA.
Did either of you edit your channel list?
Do either of you have a digital ION channel?
Do you run with Auto Clock?
Are you connected to the internet when this happens?
Was problem on internal HDD or an external USB-HDD.
etc., etc.
Edited by wajo - 2/2/14 at 10:30am
post #474 of 559
Originally Posted by qz3fwd View Post
For XFS try: http://www.pavitrasoft.com/crossmeta.html
Thanks for this info!
I'll put a link somewhere appropriate in Post #1, 2 or 3 for interested users to peruse and see if they can use their downloadable files. They have a downloadable "JumpStart Guide" on bottom right of this page that gives some interesting subjects, such as how to mount file systems, etc.
While the "Download" section states it's for "Windows 2000, 2003 and XP,"  the Introduction in the JumpStart Guide says "Additional support added for Vista/Windows 2008 and Windows 7."
I've never heard of these people before and they sound "foreign" so caution is advised (like virus- and root-kit-check everything)?
Edited by wajo - 2/2/14 at 10:46am
post #475 of 559
etc., etc.
I am using OTA
Did not edit channel list
No digital ION channel
Auto Clock at that time ---not sure
Internet connected ---not sure
HDD or USD-HDD ---not sure
post #476 of 559
etc., etc.
I am using OTA
Well, at least we might have narrowed the list? :D
post #477 of 559
etc., etc.
Here are my settings now (ie after i solved the problem).
Ota : yes
I do not know what a digital ion channel is, so i guess, no i do not have that
Edit channel list: no (never)
I do not think this is channel specific
Auto clock : off ( was ON before)
Connected to internet : yes ( but i am connected right now and the problem is gone)
I only used the internal hdd so far.
Auto power off is ON,
Hdmi resolution: fixed to 720p ( was set to AUTO before)
I remember i went to setup, other, and ran the initializations
I also changed my PIN
Important piece of info : the problem is specifically linked to the use of the timer programming. Direct recording (REC button) always worked.
I purchased and used the dvr in canada. I am in the montreal area and see CAN and US channels, but again i do not think this is channel specific.
Edited by Mtl77 - 2/3/14 at 9:51am
post #478 of 559
Ion is a TV network that shows 50% repeats of crime dramas and 50% infomercials.
post #479 of 559
Ota : yes
I am the one who also had the problem and based on what you are reporting I am guessing it was the channel we had set the Auto clock to get its time from or the HDMI resolution setting. Of the two, the Auto clock would make the most sense since it was timer programming specific.
post #480 of 559
Hi mwg1
Auto clock would make sense.
I might try reversing to auto clock see if that triggers a black screen
  Back to Forum: HDTV Recorders
