AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › HSU VTF2-MK4 or Outlaw LFM-1EX
post #1 of 10
trying to decide between these 2, the HSU is cheaper but less watts then the outlaw, need some opinions on these, room is 15x18, I would use it with a pair of golden ear aons, I am more music oriented, but some ht, thanks
post #2 of 10
The Outlaw will hit lower with more spl. It is the better choice out of those two. However, a few better choices than either for not much more money would be: SVS PB-12 NSD, HSU VTF-3 Mk-4, and the Power Sound Audio XV-15.
post #3 of 10
Blake, I would say the Outlaw EX is on the level with any of those subwoofers. The VTF2 won't be quite as powerful, but its using a slightly improved version of the same driver as the Outlaw which won't be as stressed due to less current and smaller enclosure, so I am guessing it won't achieve quite as high distortion levels as the Outlaw. In other words it should stay cleaner when pushed hard.
post #4 of 10
I definitely do not think it's the level of the ones I listed.
post #5 of 10
Another option worth considering in the same price range as the VTF-2 is the Rythmik LV12R.
post #6 of 10
Compare its performance to the PB12 or XV15 here at data-bass.com.
post #7 of 10
post #8 of 10
make sure you are subtracting 9db comparing HSU 1m peak numbers to Data-bass.
VTF-2 Cea2010
20-31hz- 112.1 db
40-63hz- 118.9db
PSA XV-15 Cea2010
20-31hz- 117.1db
40-63hz- 125.1db
PB12NSD Cea2010
20-31hz- 115.6db
40-63hz- 118.1db
Edited by basshead81 - 11/6/13 at 7:03am
post #9 of 10
I've had my VTF2-Mk4 for 18 months now & love it. My living room is 14' x 18'. Just upgraded my towers to Polk RTi A7s & am immersed in rich beautiful bass! I didn't have the option to audition subs, had to go by what I read etc, couldn't be more pleased! Basically, whatever works for your budget I would imagine? biggrin.gif
post #10 of 10
VTF-2 Cea2010
20-31hz- 112.1 db
40-63hz- 118.9db
PSA XV-15 Cea2010
20-31hz- 117.1db
40-63hz- 125.1db
PB12NSD Cea2010
20-31hz- 115.6db
40-63hz- 118.1db
