AVS › AVS Forum › A/V Control & Automation › Remote Control Area › One For All URC-7140 with WMC, can't press any button twice
post #1 of 3
Hi all,
I've bought a One For All URC-7140 from my local hardware place on a whim. I wanted to replace my MIcrosoft RC6 remote for WIndows Media Center with it.
The problem is that although It learns the buttons fine (using the individual button learning method), I can't use any button twice in a row...!
For example, if I press 'left', it's recognised as 'left'. If I press it again, nothing happens. I would have to press another button before I could go 'left' again. Same applies to any of the buttons I've trained.
Does anyone know if there's a resolution to this? It's sadly unusable as it is :(
Thanks for any help.
post #2 of 3
Do a google search for Debounce and WMC.
post #3 of 3
That remote has a code for MCE. You didn't need to learn anything.
  Back to Forum: Remote Control Area
