AVS › AVS Forum › Audio › Speakers › Yet another "Help me choose" thread
post #1 of 14
Helping my dad (60+) put together a new HT speaker system this weekend.
I use Paradigm and have forever. Love those speakers - have a thread going on in there.
Any other speaker manufacturers I should look at? Budget is $1500, without receiver.
I have several dealers nearby (Monitor Audio, Paradigm, B&W, etc).
Thanks for any input.
post #2 of 14
Room size?
Any physical considerations such as size or color?
Any listening preferences?
post #3 of 14
Originally Posted by bladerunner6 View Post
Room size?
Room Size: 16 x 24
No considerations, other than the surrounds can not be ADP-type.
Listening preferences is 70% TV / Sports and 30% Movies
post #4 of 14
Have you considered ordering online - or, do you really plan to set this up this weekend?
post #5 of 14
Really looking at this weekend.
post #6 of 14
Depending on some serious deals - may be hard pressed for $1500 from a dealer
Look at Monitor Audio and Focal for some closeout prices
post #7 of 14
Maybe just start with a pair of towers for now. With a single listening position they should create a good phantom center and you can get by without a sub for the time being. Add in a center and sub, and surrounds down the road, it will be a good way to end up with a nicer system.
post #8 of 14
Whereabouts are you located?
post #9 of 14
Dallas, Texas area.
Really want to give them something decent, but nothing crazy expensive. They have been using a cheap Pioneer-in-a-box set from 1995. So, really, anything will be an upgrade.
post #10 of 14
Dallas, Texas area.
Fry's has a number of stores in your area:
http://www.frys.com/ac/storeinfo/storelocator
They have some Klipsch speakers on sale for $100, ending today 11/07.
Also, ending today they have the highly thought of Pioneer Speakers and a Yamaha Receiver on sale.
In terms of a sub, there is a lot of support on this forum for ID subs, so perhaps buying them the speakers and receiver and ordering a sub would work well.
Also, you could check out Best Buy for closeouts or sales:
http://www.bestbuy.com/site/olstemplatemapper.jsp?id=pcat17096&type=page&ld=32.765137&lg=-96.898529&rd=25&usc=pcmcat241600050001&nrp=50&smff=Brand~@~
Edited by bladerunner6 - 11/7/13 at 9:34am
post #11 of 14
Is it best to get all new speakers, rather than repurpose my old Paradigm Monitor 5 V3 and CC-370?
They are about 9 years old, and have been treated very well.
post #12 of 14
Are you thinking about buying new for you - and giving you father the Paradigm?
If changing speakers and starting over 3.1 is a good beginning, or 2.1, or 3.0 if you
have a decent sub.
The V3 Monitors are old school and a little behind the times.
post #13 of 14
Possibly.
I may just go to Best Buy and look around.
post #14 of 14
Revel, KEF, RBH, B&W, MA, Paradigm, PSB, NHT, Focal, Dynaudio.
  Back to Forum: Speakers
