AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Advice on media cabinet for a wall mounted TV
post #1 of 4
Hi Folks. I was wondering if you had any suggestions for picking out a media cabinet. The TV will be wall mounted so actually HOLDING a TV isn't an issue. I was wondering what folks who don't have to worry about the size of their TV typically select and why. The TV is a 65 inch... will selecting a media cabinet that's too narrow look awkward?
The largest/deepest component I have to worry about is the receiver which runs about 14 inches deep.
Thoughts?
post #2 of 4
If I were putting a TV on the wall, I would hide the media cabinet in a nearby closet or a corner, not stick it under the TV. Just me.
post #3 of 4
appreciate the reply but that's not what I'm going for. Any suggestions for what I'm actually asking about?
post #4 of 4
I used ikea BESTA because it was cheap. I think similar to TV width looks best. Also, what about speakers? If wide, then bookshelf and center speaker can be placed on it, narrow, and floorstanders can go beside it.
