AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Advice please: JVC DLA-RS4810 or Runco LS-3
post #1 of 4
Hi. I need some opinions, please? Should I purchase a JVC DLA-RS4810 or go with a Runco LS-3? I see benefits both ways. Is the 4K e-shift technology worth going with the JVC? Thanks for your advice!
Tim
post #2 of 4
Tim
What do you want to use your projector for, sports, 2D movies, 3D movies, gaming?
Screen size?
Screen gain?
Throw distance?
What is your room like?
post #3 of 4
Screen size?
Screen gain?
Throw distance?
Hi,
I'm wanting to use the projector for sports and movies. I do not care about gaming or 3D. I am probably going to purchase a Stewart Firehawk 123 screen. We will probably be sitting about 15ft from the screen with the projector right behind. The room is open (not a dedicated room) with carpet and soon to be a built stage probably. The walls with the screen will be fairly dark. Lighting will be fairly controlled but not perfect. I do not know what screen gain means. I'm obviously a novice to this type of technology...that's why I appreciate your help!
Tim
post #4 of 4
Hi,
Tim
