XBMC Dumb Question
post #1 of 5
Can you edit the categories displayed in XBMC? For instance remove all except settings and movies?
post #2 of 5
Typically the Skin will offer some abilities to customize itself. Such as...
Confluence - System - Appearance - Skin - Settings - Home window Options
Beyond that you'll need to dig into includeshomemenuitems.xml... a few googles will help.
post #3 of 5
Cool. I'll dig into that.
post #4 of 5
I use Aeon Nox, which is excellent for customizing UI.
post #5 of 5
Cool.
