AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Klipsch Subwoofer 6?
post #1 of 9
Hello,
I was just given a Klipsch "Sub 6". I have tried looking this up, but can't find much about it. I don't have an amp to power it but am looking for one. Is this a good woofer? I'm thinking about on getting the Denon AVR X1000. Would this be a good buy?
post #2 of 9
A quick Google for "Klipsch sub 6" says it has a 6.5" driver and an 80W (RMS?) amp. It might be a good woofer, but IMO it's not much of a subwoofer.
If it has the features you want/need and it fits your budget, yes.
post #3 of 9
What do you mean by this? do you not think it would be a good movie woofer?
post #4 of 9
Good subs for HT go down to at least 30Hz. Six inch drivers don't, at least not with enough output to be heard more a few feet away. Real HT subs are loaded with at least ten inch drivers.
post #5 of 9
Thanks for the info, understanding now. So, would this thing not sound good at all? I was going to buy a receiver for this thing but I guess not no more... or should I buy it anyways and just use it for the time being? My bedroom is quite small 12x12.
post #6 of 9
So, would this thing not sound good at all?.
It won't go very low or very loud, so I wouldn't bother with it. It's intent isn't as a real HT sub, it's made to add a measure of bass to very small mains that only go down to 160Hz or so.
Are you aware that you'll need main speakers as well? And, AFAIK, the Sub 6 is powered.
post #7 of 9
post #8 of 9
They came with speakers as well... It looks like it was the whole package from the HD300 they used to offer.
Originally Posted by bad1550 View Post
Selling my RW-12D
See below
http://newyork.craigslist.org/wch/ele/4186717258.html
Appreciate it, however, I'm saving up for the HSU
post #9 of 9
Yes, I just picked up HSU VTF-15 and love it!
Now need to sell Klipsch to offset huge cost
