AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › media room in basement: need advice on media closet inputs/wires
post #1 of 8
I'm planning on wall mounting my TV and putting all media components in a dedicated closet.  Basement is not yet finished so I'll be pulling wires from the TV to the closet inside the walls.  However, I'm not entirely sure what types of jacks I need in the wall-plate that terminates under the proposed location of my TV.  The media closet will house an A/V receiver, cable box, Roku and Xbox.  Can I can connect all these devices via HDMI to the receiver, and then have a single HDMI cable that goes from the receiver to the TV?  If that's the case, I think I only need a single HDMI jack on my wall-plate.  Does this sound right?
Any other tips about my proposed installation would be much appreciated, as I am a complete noob when it comes to this stuff.
-Mitch
post #2 of 8
Sounds like you are using the TV as a monitor with the sound from the receiver. Only HDMI and power are required. As a future proofing, I might suggest running a second HDMI and an ethernet jack (for smart TV functions). Otherwise you don't have to make it any more complicated than it is. smile.gif
post #3 of 8
HDMI, plus at least 2 cat5e / cat6 wires (to allow for Ethernet, HDBaseT, or something else), but if you want to truly be future-proof, run a flex conduit (empty) so you can add wires in the future...
post #4 of 8
And don't forget to add a pull string in the conduit to help pull the cable when and if needed.
post #5 of 8
Make sure to have conduit.
Also, you'll want to run an extension for the Xbox Kinect (when it becomes available).
post #6 of 8
I'm not sure I follow. Do you mean that I should run 1/2" steel conduit from the TV to the media closet?
post #7 of 8
Hi gator,
Many TVs come with Netflix,YouTube apps bundled. Will I be able to pipe sound from the TV back to the receiver using the same HDMI cable?
post #8 of 8
Not a rigid steel conduit, rather a flexible plastic (PVC) conduit meant for this purpose. Generic name is "Smurf tube" because the general-purpose stuff is bright blue. Carlon Resigard is one of the brands for the (orange) low-volt version (either will work). You'd like 1-1/2" conduit if possible.
If both the TV and the AVR support the HDMI v1.4 feature called "Audio Return Channel" (ARC), you can do that.
Jeff
