AVS › AVS Forum › Audio › Soundbars › ht-ct260 sound settings
post #1 of 4
Can anyone recommend what sound settings they use for this sound bar? I use it in my rec room and I am trying to get it to deliver the best sound possible? Also, where should the sub be placed?
I am considering the Vizio S4251w-B4 because of the 5.1 experience.
post #2 of 4
Anyone?
post #3 of 4
Any help?
Sent from my iPhone 5S using Tapatalk
post #4 of 4
I bought one of these to try. On the tone menu I have bass maxed. On the subwoofer volume I have it max at +6. I redid the pairing even though light is green. I can feel some vibration with my hand touching the speaker cone, but otherwise no bass at all. I see folks complaining bass may be too much. I wonder if I got a bad system. The sub does work, but weak is an understatement. Ideas?
  Back to Forum: Soundbars
