AVS › AVS Forum › Audio › Receivers, Amps, and Processors › What to look for in $1200-1500 range?
post #1 of 3
Have been out of the loop for while but a friend asked if I could help him out.
Basically which receivers would you recommend to chose from?
E.g. 3-4 models that would be the best bang for the buck at the moment.
The only fixed demand is at least 4 HDMI inputs.
Easy navigation is a plus, either via OSD or android App.
post #2 of 3
The new Denon X4000 with Audyssey MultEQ XT32 and Sub EQ HT (dual subwoofers) although not sure if in that price range in Sweden.
post #3 of 3
Thx, for the input
