AVS › AVS Forum › Display Devices › CRT Projectors › nec pg6 plus "create new input" help needed!
post #1 of 3
hi
i just got a used pg6 plus and from there on it got messy
after several successes i am stocked now.the pg wont let me store the picture settings telling me "can not store no entry".. fine, as i fpound out i have to create an input first. but how. in the input list i only see some, but cant create new!
(also, if i get into the info menue and try to select anything it only says "key input error" - but i mention this only just because i tried to find a solution there.. )
please fellows, am starding to get mad with my crt.. help
post #2 of 3
ok, figured it out myself. just had to enter the adjust menue, and for that manner "READ YOUR MANUAL"...)
thanks
post #3 of 3
for the NEC PG this guide also covers some things which might not be perfectly clear in the factory manual
http://www.curtpalme.com/NECPG_MechSetup1.shtm
  Back to Forum: CRT Projectors
