AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Owners thread Sony Hw55ES
post #1 of 1027
My first short impressions(coming from a epson tw9000).
The good:
A razor sharp picture does this unit throw at your screen..
Amazing contrast(a step up from my epson).
Very very good blacks.
No more screendoor(i sit very upclose and i saw that on my epson.).
Reality creation gives 3d more clarity..
3d is sharper and it has far more details then my old epson..
FI works good in 3d
More then enough light for my 100 inch screen in 2d.
The bad:
Still ghosting in 3d(sometimes more then my old epson tw9000)
The ir transmitter inside the sony unit is not that strong( i have it on the same place sitting where my epson was but now i loose sync
i can see some flicker through the glasses that was better(less) with the epson..
But its a great projector with great pop and depth in the image and razor sharp!
So this is just my opinion and not a professional review..
Best regards:)
Edited by john2910 - 11/12/13 at 12:30pm
post #2 of 1027
Go into the servicemenu and you can increase the strength of the IR from 0 to 1. Service menu enter, enter, left arrow, enter then yes
post #3 of 1027
Sorry that is for the iris i think...
Best regards
post #4 of 1027
John,
What's your throw for the 100" screen? I'm coming from an older DLP - I can't wait to get mine!
Aaron
post #5 of 1027
The good:
FI works good in 3d
The bad:
Best regards:)
You're always going to have more flicker with this vs your old Epson TW9000. The Epson has 480hz panel drive in 3D, whereas the Sony is 240hz 3D. The difference is massive. It's one of my biggest complaints with the Sony HW50ES (and the 55ES) is that the flicker is insane compared to my old Panasonic PT-AE7000 and PT-AE8000 which both used 480hz 3D like your Epson did.
I hope we see an overhaul of these SXRD projectors next year to better implement 3D, because right now it's a weak link in the Sony. Not as weak as the JVCs, but weak nonetheless.
Thanks for the impressions!
post #6 of 1027
Originally Posted by Aaronh View Post
John,
Aaron
Hello there,
Mine is at 3 meter 40 cm with max zoom...
Best regards,
By the way your gonna love the sony..
post #7 of 1027
Great- Looks like I can definitely mount in the same location.
Looking forward to watching some movies - sold my old PJ over a month ago.... and sports on a 32" screen just isn't cutting it!
post #8 of 1027
Well I wouldn't use the term "insane" but I would agree that the flicker in 3D is the Sony's Achilles heel. It's supposedly better in the 4K projectors, so maybe it's not a limitation in the LCOS technology itself.
That being said there's many a movie where the Sonys give an immensely satisfying 3D experience. It's only in scenes with rapid motion, that the flicker becomes apparent.
post #9 of 1027
I think it is, indeed, highly subjective. There are moments when the flicker and motion issues are just insane in 3D, for me, on the HW50ES. frown.gif
post #10 of 1027
Yes, Tintin is just too hard on my eyes in 3D due to all the flicker. Yet I was not distracted by flicker at all during Finding Nemo. I think it is important to emphasize the flicker in the Sonys only is evident when watching in 3d and only in scenes with fast motion. It's not like watching the old film projectors where the flicker was evident between every frame of film.Many movies still look great in 3d on the 50ES and I'm sure the same is true for the 55ES as well.
I've noticed ghosting only the once, and I reduced the glass from the max value to the next level down and it became imperceptible. There's lots of talk about ghosting but to me it's not really a problem and certainly nowhere as evident as the flicker.
post #11 of 1027
Yes, Tintin is just too har don my eyes in 3D due to all the flicker. Yet I was not distracted by flicker at all during Finding Nemo. I think it is important to emphasize the flicker in the Sonys only is evident when watching in 3d and only in scenes with fast motion. It's not like watching the old film projectors where the flicker was evident between every frame of film.Many movies still look great in 3d on the 50ES and I'm sure the same is true for the 55ES as well.
Agreed on the ghosting. The HW50 is terrific in this regard. And yes, I lowered the glasses from the max value to one lower, and that completely reduced the ghosting to imperceptible, as you say. The max level is just not acceptable to me, and one level down is great.
post #12 of 1027
+1
I have seen a couple of 3d movies now and you only see it in very very bright scenes.. and its not that bad..
post #13 of 1027
I am gonne try that tintin movie and see how it is on the sonyhw55;)
post #14 of 1027
I have the HW50ES and the IR transmitter in my unit only worked on the Sony glasses and would drop sync on occasion. AVS was able to get an external IR transmitter to me for free which resolved the syncing issues.
I'd wonder if it would be worth it for you to get the RF transmitter and glasses.
post #15 of 1027
The HW55 doesn't come with a spare lamp, instead Sony provides a voucher with the purchase. This should be in the box. If not, I would contact whomever you bought it from and request the voucher.
post #16 of 1027
I ordered the rf transmitter,
post #17 of 1027
post #18 of 1027
Yes, please let us know how the RF version compares to the IR version. Be sure you get the RF glasses as well. smile.gif
post #19 of 1027
Today i watched tintin,
That one looked absolutly stunning:) on de sony hw55es,almost no flicker..
post #20 of 1027
I will;)
post #21 of 1027
Didnt i only have to order the Optoma 'ZF2100' rf glasses with that emitter that comes with it and plug that straight in the sony hw55ES?
So i didnt have to buy that sony emitter or am i wrong?
With the optoma i can play with the settings like duty cycle etc....
post #22 of 1027
Well, you're one of the first to have the 55ES - I guess you'll answer that question for the rest of us! wink.gif
post #23 of 1027
Pretty sure you're gonna need to get the official RF transmitter and 3D glasses from Sony.
Data below pulled from the specifications tab on the Sony link.
- Transmitter: Optional external transmitter (TMR-PJ2)
- Glasses: Optional rechargeable glasses (TDG-PJ1)
It wont hurt to test out what you're doing now, but I would got with the equipment that was specifically designed for the HW55.
post #24 of 1027
If you can read German then here is a nice review of the sony Hw55ES:
http://www.areadvd.de/tests/video-test-sony-vpl-hw55-wie-gut-ist-er-wirklich/
post #25 of 1027
So today i got the rf emitter(AD025_RF-X1)and a sony TDG-BT500A .
Is there a difference in ghosting ?
No there isnt..
But they Always stay in sync no matter what i do.
But after some more testing i prefer the 3d3 glasses(i had them still laying around from my old projector) they accept ir signals and rf signals..
And they are more comfortable.
The sony glasses that come with the hw55es are hurting my nose:rolleyes:
And if you move head a little they show easier some ghosting.
Now i have connected for my situation an external ir transmitter and now the ir glasses keep in sync also..
i watched tonight the movie planes and it looked great with very minimal ghosting..
Sorry for my bad english..
But i hope you like the information..
post #26 of 1027
They look better in real life its hard to capture a good picture..( so the colors are a bit off and a bit softer)
post #27 of 1027
Absolutely glorious. Making the wait even more difficult....
post #28 of 1027
They even look in real life much better;)
You will enjoy it..
post #29 of 1027
You will enjoy it..
Looks great! Blacks look good.
post #30 of 1027
