AVS › AVS Forum › News Forum › Community News & Polls › What Are Your Favorite Soundbars?
What Are Your Favorite Soundbars? - Page 3
post #61 of 82
Originally Posted by mark haflich View Post
Scott. There definitely has to be a distinction powered and unpowered and then needing a sub or not. And then there is the question of sound quality which the Sonos Playbar is just average at best. The problem is people like it but just don't realize how much better sounding stuff is out there. I too am looking for one.
To keep things manageable, I've decided to limit this guide to powered soundbars, because they serve best as a replacement for the TV's onboard audio. As for subwoofers, the vast majority of soundbars need one to sound their best—the only ones I'm considering for the guide that probably don't are the Atlantic Technology 235 with H-PAS technology and the Zvox 580, and maybe the SpeakerCraft CS3. From what I've read (including a review just posted by imagic on AVS), the Sonos Playbar actually sounds very good as long as you include the Sonos Sub. Many AVSers have recommended including the PlayBar in the guide, and many pro reviewers also include it in their top soundbar lists, so I think I'm going to include it (along with the sub) as well.
post #62 of 82
I purchased a Sony HTCT-260H and I CANNOT recommend it. The wireless subwoofer goes into standby mode quickly and will not awaken unless you cycle the power on the soundbar.
post #63 of 82
I have to say the Bowers & Wilkens Panorama is the bed I have heard.  It can fill  room of almost any size and is great for music, as well as TV.  It isn't cheap, but worth the price.
post #64 of 82
I use the Panorama in the kitchen and while i think it's the best 1 piece unit for tv and blu-ray movies, I do not like it at all for music. A pair of Dynaudio Focus 110As with built-in amps can connect to the tv or anything else and are my favorite small audiophile speakers.
post #65 of 82
I agree that there are MANY superior options if looking beyond a sound bar.  But if forced to look solely at Sound bar's for a choice, I do like the B&W (and actually the Energy as well for bang for the buck).
post #66 of 82
The Wirecutter website has an article on soundbars. For the budget 'bars, he likes one of the Vizios (see the article for model number). For high end powered 'bars, he recommends the Martinlogan Motion Vision, which costs around $1100. He also likes the Atlantic Technology Powerbar 235 (about $650). He also says the Goldenear 3D Array ($1100) has the very best sound, but it is passive and must be driven by an AV receiver. I live in a small town hours away from the nearest city and haven't been able to listen to any of these 'bars. If i buy one, I'll have to buy it on the internet "sight unseen," er, "audio, unheard." Has anyone listened to the Atlantic, Martinlogan, or Goldenear?
post #67 of 82
Pic of the B&W Panorama above the Panasonic TV.
post #68 of 82
Whhuu...? Why??
post #69 of 82
Well, the middle cutout fits the oven and with the tv above, it went higher. Besides, Audio 101, the higher you go, the better the high frequencies. smile.gif
post #70 of 82
Found a cheap and seemingly decent soundbar with wired sub on Amazon: The Samsung HW-F355. I've just ordered it a few hours ago for a small bedroom. Let's see how it turns out.
post #71 of 82
Can any of the soundbars be connected to a receiver? I prefer to have optical cables from blu-ray player and cable box going to my HK receiver and then to a soundbar?
post #72 of 82
Originally Posted by [Irishman] View Post
Whhuu...? Why??
Wow -- a sound system that goes from 20 Hz all the way through the microwave spectrum --
Is there a crossover between the soundbar and the microwave emitter? smile.gif
post #73 of 82
Using a soundbar defeats the purpose of a receiver.
post #74 of 82
I guess you mean that you want to switch between different optical sources, but most soundbars have only one optical input. Well, you can use your TV as the switch. Most TVs have an optical output. You can plug your sources via HDMI to the TV and then the TV will output to the soundbar via optical.
post #75 of 82
I'm concerned how the Panasonic plasma will process DD and DTS and output through the soundbar?
post #76 of 82
Most likely it will pass through those streams. You can test it with your receiver. Connect the source to the TV and the TV to the receiver via optical. Also, modern soundbars can accept those streams, but make sure before buying.
post #77 of 82
post #78 of 82
I just bought a new house and moved in this week and was thinking that a soundbar would be a good way to keep the living area from looking unorganized/cluttered. I currently have a HK receiver and Velodyne 5.1 setup that sounds fantastic, just need a smaller sub. I don't want the audio equipment to overtake the living area which is 9ft wide x 12ft long, under 1000 cubic ft.
post #79 of 82
Have cable running into an Oppo 103, video out to tv and am looking for a soundbar to hook up to the Oppo's audio out...... can be HDMI or any other combination. Just want good sound without spending an arm and leg for it........................... Am going to my Best Buy to look at the Klipsch, ZVOX and Pioneers mentioned in this thread...........
post #80 of 82
Okay, after 4 days of visiting 4 different Best Buy stores in the Greater Kansas City area to check out soundbars, here are my findings. They have a wide assortment of soundbars set up for a person to listen to, but, NONE of them outside the Magnolia room had the sub hooked up, and none of the ones outside the Magnolia room had remotes. Of course at every store they tried to push me into either a Sonos or an Energy sound bar from the Magnolia Room. I listened to the Klipsch SB1, Pioneer Sb23W, and the Sony 660,that were mentioned here, but none had the subs hooked up, so I couldnt get an actual idea as to how they sounded. They had the Zvox 580, and the Bose Solo, but of course none of them had them hooked up for a person to listen to. I listened to all the soundbars they had on display outside the Magnolia room, but again, couldnt tell due to no sub being hooked up.
The soundbars/systems inside the Magnolia room were all in excess of $1000, which is above my budget for now. I still have no idea how any of these soundbars sound as a unit with the sub hooked up, so I am off to Nebraska Furniture Mart where I will hopefully find some of these previously mentioned soundbars actually working with the sub connected and the remotes available to play with the settings. WIll check back in with my findings...............
post #81 of 82
Pinky
Even with subs hooked up, it is almost impossible to get an accurate impression of how any of the soundbars you mention actually sound. If you are serious, purchase one, take it home. If it sounds good and performs well in your room with your equipment, keep it. If you feel something is lacking, return it and try another. I would trust professional reviews over what you actually hear, even in a Magnolia sound room, in a large cavernous building. I am an experienced listener, sadly with older ears that are now missing a lot of audio. In my search for either small speakers or a soundbar to replace my full size tower speakers and sub-woofers, I brought many items home and can tell you that many that sounded promising at Magnolia or a few other dealers fell short when placed in service in home.
I think most of your choices are promising and most are reasonably priced.
One further note. As with much in the audio world, price has almost zero correlation to sound.
David
post #82 of 82
David,
I know all about the "old ear" syndrome to which you refer.....lol.... And I do realize the difference between the large room vs where I will be using it. Have read horror stories about returning things to BestBuy, so just wanted to go look at features and get a general idea of how they sound, and the settings one can customize. I figure the Magnolia Room incident was just Best Buy trying to up-sell something in my personal opinion. I did go and listen to some soundbars at Nebraska Furniture Mart in their more realistic sound room, and found a few I liked, however, I think I am going to wait a little bit and see what reviews people give the new Denon DHT-S514 soundbar thats due to hit store shelves (per a Denon rep) in 2 more weeks, Mid January 2014. A good friend has been trying to steer me away from soundbars all together, and get a "real setup", ie...rcvr, speakers, etc..... his preference has always been Denon. I showed him the URL for the soon to be released soundbar, and he found nothing wrong with the specs, but like you, and I agree, need to see some reviews, make a choice, buy it, and see how it sounds at home......
Bill
  Back to Forum: Community News & Polls
