AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic ST50 display settings change with Netflix
post #1 of 3
Hello. I am such a novice, so please forgive a possibly simple problem. I have followed some recommendations for display settings and am happy with overall viewing of HD cable and DVDs. However, when I hit the Netflix button and watch content the screen darkens and appears to be "green" saturated. Why would the display settings change with Netflix? Anyone have a possible solution?
post #2 of 3
Each input including netflix has it's own picture settings. You need to adjust or copy / paste the settings you want by pressing the menu button on the remote with the netflix app running then select picture. Hope this helps.
Nick
post #3 of 3
As a further testament to my newbness, I can't even accurately describe my TV. It is an ST60 not an ST50. Either way, your advice worked. Thank you so much for the quick reply. I was able to greatly improve my Netflix display. I'm sure as I try to learn more about the TV and optimize the settings, I'll have more questions. Nice to know there is a helpful and knowledgeable forum here.
